Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
Old 06-09-2008   #1 (permalink)
Favorite Bike: 1976 Bonneville T140V
Kickstart spring replace/right footpeg removal
First, let me start with a thank you to this forum for all of the valuable info available. I've already found a wealth of tips for replacing a broken kickstart spring in my '76 T140.
I was able to get the outer gearbox cover off without fully removing the right footpeg, but I don't think I'll be able to get the whole thing back together without removing the footpeg entirely. Right now, the rear brake pedal is preventing the footpeg bolt from being extracted.
Do I need to remove the rear brake pedal in order get this bolt out or maybe adjust the rear brake pedal out of the way somehow? Any info is much appreciated.
spearce72 is offline   Reply With Quote
Old 06-09-2008   #2 (permalink)
Favorite Bike: '64 Norton N15CS
McQueen's Avatar
Other Motorcycle: '79 Triumph T140D Bonnie
Extra Motorcycle: '71 Triumph T100R Daytona
I was able to just press down on the pedal to give enough clearance. But if that doesn't work, just take the pedal off. One 9/16 nut and you're golden.
Make sure any kids/wives/GFs/neighbors/pet parrots are out of earshot when you go to put the new spring on. You'll run though your entire repertoire of profanity getting that %$#@&* spring back on.
+ Ton Up Club NorCal +
McQueen is offline   Reply With Quote
Old 06-09-2008   #3 (permalink)
Thank you. Yeah, when I press the pedal down as far as it'll go, I'm still not getting enough clearance.
I removed the nut awhile back and started to pull the pedal but it didnt' want to give and I thought I'd consult before I put any force behind it.
So, any tips on getting that spring back in there? I'm assuming that I'll wind it back counterclockwise with the kickstart lever and then mate the cases. Do I need to really wind it up, or just enough to get the kicker at about 9 o'clock?
I think I'll try and get back together correctly once or twice to get a feel before I add the gasket and RTV.
If there was anything you remember that might be helpful, I'd love to hear from you.
Thanks again.
Scott
Old 06-09-2008   #4 (permalink)
McQueen's Avatar
Scott, you have to pry the pedal a bit for it to come off, but it does.
Spring, well, it takes some finesse and luck.
Here's what usually happens:
Get spring in position...smear your gasket sealer...start to SLOWLY and GENTLY slide the outer cover back on...then just as you think you've got it...BAM! The spring slips off just as the cases mate (and you gasket sealer touches the opposing surface). This is also where all the aforementioned profanity comes in.
It's trial and error and luck. You'll get it though.
Unless someone else here has the magic secret?
Old 06-09-2008   #5 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
To get the brake lever off (it's on a square shaft), undo the nut until it's outer face is level with the outer edge of the screw thread, and then give it a medium whack with a metal hammer. The shaft will move back in a bit, and the lever will pop off the square section.
The kickstart needs to be wound up 1.25 turn counterclockwise from where it would nomally sit on the stop - about 1.75 turns from the rest position with the outer cover off. If you don't wind it up this far, the wind when riding will force it back and engage the rachet.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 06-10-2008   #6 (permalink)
Ozbloke, I wish I had read your reply before I went about getting the pedal off. I went ahead and removed the nut and washer on the other end of the shaft and ended up pulling the pedal and shaft completely out..dropping the srping and bushing. Hopefully, that won't be too difficult to put back together.
Thank you for the tips on winding the spring up! I definitely don't want to be going back in the gearbox anytime soon after the repair.
Old 06-11-2008   #7 (permalink)
Favorite Bike: 1970 TR6 Spring Gold!
I'll say it agian, everyone needs to watch Hughie Hancox's video on rebuilding these engines. I followed his lead and it took all of about 2 seconds to put my kickstart spring on and mate the outer gearbox cover.
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
Old 06-11-2008   #8 (permalink)
quagmire - you're absolutely right. Those videos are both educational and entertaining. The first time I watched it I couldn't believe how many uses there are for a soft faced mallet.
503_colville is offline   Reply With Quote
Old 06-11-2008   #9 (permalink)
Just be thankfull you dont have one of those superior bikes from the far east, To replace the kick start spring on a Suzuki GT380J you have to split the crankcase in half
A wise man learns from his mistakes..
A genius learns from other peoples mistakes.
panda is offline   Reply With Quote
Rear Footpeg Removal??? AceT100 Twins Technical Talk 12 11-09-2007 08:56 AM
footpeg removal Garyhjd Sprint Forum 8 10-23-2007 02:05 PM
Kickstart Spring jonkull Classic, Vintage & Veteran 9 08-16-2007 11:52 PM
kickstart watch spring unsprung johnnypence Classic, Vintage & Veteran 9 05-08-2006 12:10 PM
Spring Mods--Predators, Airbox Removal, AI Removal idaho_thrux Twins Talk 6 04-09-2006 03:30 PM
