[quote=jonkull;1050876]Well I was a little concerned because I was doing 65mph for about 7 or 8 minutes before I realized I was in 4th gear and shifted up to 5th. When my tach was working I would have shifted around 5000 to 5500 rpm and been going around 45mph (then again when the tach was working my clutch was fried). I was worried that going 65 in 4th gear had the rpms outside of a safe level. All the oil didn't make me feel any better.
Do not worry, You were nowhere near safe limits.. These things geared down often pulled sidecars. My old t100 was habitually run out to 75mph in second gear
I think if you really try, it will do about 100 in fourth
so you probably only at 65% max revs
The oil leak is probably unrelated, but check out the primary rattle, these thing tell you when they want attention.
