BikeBandit
Old 06-09-2008   #1 (permalink)
Favorite Bike: Triumph Bonneville T-100
Other Motorcycle: '68' T-120R
T-140 crank shaft?
I am attempting to put together a T-140 engine from an assortment of old parts I have. I've got one of "Kim the cd man's" Triumph editions on order but it is not here yet and can't figure out which crank shaft would go with the T-140 cases (T140V CH2792) I have. I have four or five diffrent crankshaft versions to choose from and want to get the right one (if I have the one that is supposed to go with the 140). One prime suspect is a bolt together,another looks like one of the lighter cranks (square edges) but is heavier. Also, are the rods diffrent from a T120 to a T140?
jimmy bush is offline   Reply With Quote
Old 06-09-2008   #2 (permalink)
DAGAD's Avatar
Hi Jimmy, check the crank for a METRIC 30MM journal on the TIMING SIDE. Also the T140 has a triplex chain and the drive side alternator spigot is 5/8" longer than the duplex.
The T140 rods are SHORTER and thicker. On the timing side bearing use an NUP306ECP ROLLER, NOT the ball bearing. The drive side should be MRJA 1 1/8" C2 clearance, C2 MOST IMPORTANT.
Roy.
Old 06-09-2008   #3 (permalink)
Thanks DAGAD. I'll measure the points listed this afternoon. Would the rods be like the ones ran in the tripples? Do you know what the bolted together crankshaft might be? It looks a lot like the other Triumph cranks except for that and it has no sludge tube.
Old 06-09-2008   #4 (permalink)
Woo hoo, I believe I found the right crank shaft, stator, rotor,oil pump, triplex drive sprocket and clutch basket. The spark advance mounting surface is a bit deformed from someone using too much muscle pushing too hard of a hammer but I think it can be saved. Now I need to find the rest of the transmission and a frame that is missing an engine.
crank shaft pictures needed DBS The Rocket Science Forum 1 04-22-2007 10:35 PM
Bad crank sensor? Hozer Club Cafe 9 10-26-2006 07:31 PM
63 HP at the crank! Thrux-ton-up Club Cafe 16 07-25-2006 02:23 PM
270 Crank vs 360 Crank - please explain NHScrambler Twins Talk 18 06-06-2006 04:42 PM
2000 rs crank wounlt crank KidThunder650 Sprint Forum 3 04-15-2006 05:16 PM
