BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
Old 06-05-2008   #1 (permalink)
Favorite Bike: 1977 T140V
77FREEDOM's Avatar
Extra Motorcycle: 1994 XL883 (Wife's)
Exclamation Spark Plug Question
What is the general opinion of NGK plugs?
I'll tell you why....
My 77 Bonnie was equipped with Champion plugs and decided to put another set in. Crossreferencing the numbers I was able to come up with a set of Champion N5C plugs. Ran fine. Had a local shop do some wiring repair etc. and they put in a set of NGK. While getting the Dual Amals in sync it seemed like the bike was fouling out a plug. Got the carbs set but now it coughs & sputts while at highway speeds.
Anyone with some insight into NGK plugs.... or is it time to go with some Mikuni carbs....
Appreciate the info...
"Surely you can't be serious."
"I am serious. ....And don't call me Shirley"
77FREEDOM is offline   Reply With Quote
Old 06-05-2008   #2 (permalink)
Favorite Bike: 1995 S3
Other Motorcycle: 1995 Sprint (cal)
Ngk come stock on the new Triumphs - maybe it's a fueling issue, if your electrics are good!
trypcil is offline   Reply With Quote
Old 06-05-2008   #3 (permalink)
Favorite Bike: '74 850 Commando
Other Motorcycle: '79 T140E, '96 Trident
I have always run my '79 T140E on Champion N5s, never found any others that work as well, irrespective of their 'equivalence'. NGKs are an absolute no no as far as I am concerned.
Presumably yours is a T140V with Mk1 Amals, shouldnt it have N3 sparkplugs?
daveforty is offline   Reply With Quote
Old 06-05-2008   #4 (permalink)
Favorite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
Extra Motorcycle: '62 AJS 650 Twin
I believe daveforty is correct.
However I will move this thread to the Vintage forum where there is a bigger pool of view.
Incidentally here's another thread on the same subject:
http://www.triumphrat.net/classic-vi...-73-t140v.html
Ride on !
Tbirdnz is offline   Reply With Quote
Old 06-05-2008   #5 (permalink)
77FREEDOM's Avatar
THANKS!
I was running the N5 because it was a hotter plug. The bike had Open Turn out mufflers on it when I got it & the 5 ran the best. Ive since put slightly Punched out HD Sportster mufflers on it until I get the Factory pipes put back on. I am currently running a Podtronic regulator and the Boyer Micro-Digital ignition & new battery.
I think the NGKs wil soon be gone from my bike.....
Old 06-06-2008   #6 (permalink)
Favorite Bike: 1978 Triumph Tiger 750
hobbit's Avatar
Other Motorcycle: XLH883C Sportster
Extra Motorcycle: 1978 CB750 Hardtail Chop
Been using ngk - haven't been able to get champions, but never been completely happy with them, don't seem to last well, don't think I should need to keep changing plugs after only 2-3k miles.
Amazing things indicators . . . pity yours don't work.
http://www.aavmcc.com
http://www.putfile.com/hobbitaavmcc
hobbit is offline   Reply With Quote
Old 06-06-2008   #7 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
77freedom,
I too tried the NGK's (B8E-S) and wasn't happy. Went back to Champion, and tried their N3C plugs (Copper Plus). Not a single issue after 12 months. I run the Boyer MkIII.
Pete
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 06-07-2008   #8 (permalink)
Favorite Bike: 79 t140e bonneville
I run a T140E and had NGK's and had nothing but fouling problems. Changed to Champion N5C's and no more problems.
Dirty Harry.
dirtyharry is offline   Reply With Quote
Old 06-08-2008   #9 (permalink)
Favorite Bike: The 2 I Own
Other Motorcycle: 1977 Bonneville
Extra Motorcycle: '05 Rocket lll
I said it before, I'll say it again....all my "spark plug issues" have come to an end once I started useing Autolites! I THINK the cross-reference number is 4052? 5240? Something like that. I WOULD NOT go to Mikuni's ! Amals are fine, even if you have to buy NEW ones or get the old "re-sleeved"!
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
TRI-AL is offline   Reply With Quote
Old 06-08-2008   #10 (permalink)
You should be running either Champion N-3's or NGK B-7's in a '77 T140V. An N-5 is too hot of a plug. If you are fouling N-3's, the bike is running too rich. After checking valves and timing and checking for weak spark, make sure idle circuit is not plugged. Do a search on how to clean this. Adjust idle mixture screws 1 1/2 turns out to start. If still fouling, carb jetting needs to be looked at by doing plug chops. Open pipes should not require a hotter plug. Usually they tend to make the bike run leaner. So if yours is running rich with them, I would expect a carb problem.
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline   Reply With Quote
Spark Plug Change, Airbox question??? Komodo Daytona Deliberations 6 03-29-2008 08:36 PM
Spark plug question nobodyspecial Trophy 8 10-04-2007 04:51 PM
Spark plug gap question.... KevyKev Sprint Forum 3 01-21-2007 05:59 PM
spark plug gap question sweatmachine Twins Technical Talk 10 07-15-2006 11:49 AM
Another spark plug question. Clint-Rickett Classic, Vintage & Veteran 2 05-18-2006 10:05 PM
