BikeBandit
Old 06-09-2008   #11 (permalink)
Favorite Bike: 1970 TR6 Spring Gold!
What's a comprable Champion plug for an NGK B8ES?
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
Old 06-09-2008   #12 (permalink)
bendavanza's Avatar
N5 is too hot.
Most likely your fouling problems come from worn out needle jets.
They wear quickly and will contribute to sooty plugs.
Most 650 twins call for N3 and 500's N4 (unit). I forget what the 750's use but N5 is probably too hot. I used to do the same thing to "help out" bikes in need of tuning but I know better now.
I've never liked NGK plugs on old brit bikes, Champions work great for me.
New Bonnevilles are a completely different story.
-Ben
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Old 06-10-2008   #13 (permalink)
Quagmire,
NGK and Champion plugs are not directly equivalent. A B8 is slightly cooler than an N3 and a B7 is between a N3 and a N4. N3 is what Triumph recommended for all 650's and 750's up til the mid 1978 model year when the T140E was introduced. The factory then issued a service bulletin recommending that N5 be used in the T140E's. The difference is the head design of the T140E's which do better with a hotter plug. If your bike has splayed intake ports run the N3's. If it has parallel ports run the N5's. As far as NGK 's, if you do a lot of in town riding and short trips, the B7 is probably a better replacement for the N3 than the B8, as it is less prone to fouling. If you do a lot of high speeds or sustained highway work the B8 might be the better choice.
Htown
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline   Reply With Quote
Old 06-10-2008   #14 (permalink)
I've noticed I've had some fouling issues on the right side. Left side looks good. The Triumph manual says the right side runs richer than the left on the TR6's, but I thought a change in plugs would be worth a try so I'll get some N3's and see.
Old 06-11-2008   #15 (permalink)
Favorite Bike: 1978 Triumph Tiger 750
hobbit's Avatar
Other Motorcycle: XLH883C Sportster
Extra Motorcycle: 1978 CB750 Hardtail Chop
Interestingly enough, originally the T140 was rated for B8ES, but I've noticed that even NGK themselves recommend B6ES now. Perhaps something to do with modern fuel formulation?
Amazing things indicators . . . pity yours don't work.
http://www.aavmcc.com
http://www.putfile.com/hobbitaavmcc
hobbit is offline   Reply With Quote
Spark Plug Change, Airbox question??? Komodo Daytona Deliberations 6 03-29-2008 08:36 PM
Spark plug question nobodyspecial Trophy 8 10-04-2007 04:51 PM
Spark plug gap question.... KevyKev Sprint Forum 3 01-21-2007 05:59 PM
spark plug gap question sweatmachine Twins Technical Talk 10 07-15-2006 11:49 AM
Another spark plug question. Clint-Rickett Classic, Vintage & Veteran 2 05-18-2006 10:05 PM
