Quagmire,
NGK and Champion plugs are not directly equivalent. A B8 is slightly cooler than an N3 and a B7 is between a N3 and a N4. N3 is what Triumph recommended for all 650's and 750's up til the mid 1978 model year when the T140E was introduced. The factory then issued a service bulletin recommending that N5 be used in the T140E's. The difference is the head design of the T140E's which do better with a hotter plug. If your bike has splayed intake ports run the N3's. If it has parallel ports run the N5's. As far as NGK 's, if you do a lot of in town riding and short trips, the B7 is probably a better replacement for the N3 than the B8, as it is less prone to fouling. If you do a lot of high speeds or sustained highway work the B8 might be the better choice.
Htown
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
