Sounds like the fuel / air mixture setup is wrong.
First off, have you stripped and checked that the carbs are OK? Any loose bits laying in the float bowls that shouldn't be there? Blocked air filters? OK, check the following:-
The needles set at the right hight, correct main jet sizes, slides in the right way around, mixture setup correctly, choke slides are fully up, throttle cable/cables pulling equally so the carbs are balanced.
In fact, just do a basic carb set up from scratch before you start looking for electrical problems. Good luck!
