Help:- headlight retaining clip. - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 05-21-2008, 01:04 AM Thread Starter
Main Motorcycle: 5T 1958 SPEED TWIN
pre unit Thruxton's Avatar
Other Motorcycle: 1959 Triumph Bonneville
Send a message via Skype™ to pre unit Thruxton
Question Help:- headlight retaining clip.
Could someone please place a photo or discription how to fit headlight retaining clip on nacelle type headlight rim?
BB
pre unit Thruxton is offline
post #2 of 6 (permalink) Old 05-21-2008, 01:59 AM
DAGAD's Avatar
Hi Bushy, do you mean the wire clip to hold the light unit into the rim OR the single screw which holds the rim to the nacelle adaptor? The wire clips I use are from greenhouse glass retaining clips, usually 4 or 5 at a time. The single screw / clamp is the same for normal headlight units and the long side goes to the rim, short side to the adaptor ring.
Roy.
DAGAD is offline
post #3 of 6 (permalink) Old 05-21-2008, 02:44 AM Thread Starter
Hi Roy
Having not had the original parts, I now have them and for the life of me I cannot figger out how the lot comes together. I'm referring to the light unite into the rim with the wire clips which are W shaped, (I believe there are different wire clips) and yes they are original Lucas parts. If I can get that part done the rest SHOULD be easy.
BB
post #4 of 6 (permalink) Old 05-21-2008, 03:48 AM
Main Motorcycle: 1970 BSA A65 Lightning
Monty's Avatar
Other Motorcycle: 98 Thunderbird
Extra Motorcycle: 79 Bonneville Special
1}Place the headlight into rim
2}fit the top of the "W" into the curled part of the rim.(the part that pushes onto the headlight shell)
3} push the bottom of the "W" onto the headlight edge, making sure it sits in the raised metal holders.
The clips are spring loaded so will bend a certain amount.
This is how i do my T140, i dont know which Triumph you have.
Slightly rippled with a flat underside
Monty is offline
post #5 of 6 (permalink) Old 05-21-2008, 04:59 AM Thread Starter
Thanks Roy & Monty - done.
BB
post #6 of 6 (permalink) Old 05-21-2008, 04:29 PM
DAGAD's Avatar
Hey Bushy, how many times did you stick your finger getting the clips in....... ha ha ha.
Roy.
DAGAD is offline
Clip Ons nodlive Air Cooled Twins Technical Talk 6 05-10-2007 11:44 AM
clip on help!!! RevLMTRh8tR Speed Triple Forum 1 04-02-2006 10:25 AM
CLIP-ONS???? AndrewTriumph Speed Triple Forum 5 03-23-2006 06:00 AM
clip ons wiayeman Speed Triple Forum 9 04-21-2005 09:10 PM
Clip-Ons jbhotchkiss Daytona Deliberations 4 04-15-2004 07:20 PM
