I've been on the scout for a 5-speed for a while and in decent shape they are going for $500 minimum. Some case work may be required. Mecchanica has stated that the first couple of years of the 5-speed are not a desirable as later 5-speeds. I understand the swap out is not too difficult, but does require some skills.
Do a search on this site as I think the whole process has been discussed in the past. There is also an eBay seller who is selling a small text on doing the swap, so you could try looking there.
The real advantage of the 5-speed is that it permits a higher final drive ratio (lower numerically) while keeping first gear reasonably low (higher numerically).
Reason: spelling correction; add last sentance
