» Log in
User Name Not a member yet?
Register Now!
Old 4 Days Ago
Newbie
Favorite Bike: Love em all
Other Motorcycle: 04 and 01 Hayabusa's
68 650 Chopper-'Rough Running' Question
Hi. Great forum. I just bought a 68 650 Triumph chopper. I am not a new chopper fan but this thing just exudes coolness. The bike wasn't ran enough and it needs some TLC.
My son cleaned the carb (it was a mess!) and replaced the plugs but the bike still will not run well with the throttle open more than a quarter or so. Does it need to be under load to really check it? it is raining here so we just ran it in the garage. He thinks the points might need adjusted but needs help with that since this is new (old??) to him.
Any of you Triumph vets have any insight to offer? The motor was rebuilt top to bottom in 06. Any help or insight will be greatly appreciated. Jeff
Old 4 Days Ago
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
It could be carburation; you really need to soak the metallic parts in Berryman's Chem-Dip for 1/2 hour, then carefully check each passage, and rebuild them very carefully. Tweaking the low speed mix is critical, and replacing main jets, needles and needle jets as a set is the best advice.
It could be ignition timing, or improper adjustment of the points, weak or failing coils and/or condensers. Top-to-bottom careful analysis of all of these is in order.
Careful adjustment of the valves should be done, and clean air filters are a must.
Fully charged battery is a good thing. NEW CHAMPION N3C PLUGS FOR SURE!
Welcome to the forum, and the wonderful world of old bikes.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 3 Days Ago
Newbie
Thanks a lot!! I will tell my son and post up what happens. I have only owned newer bikes so this has been an adventure but well worth it....so far. thanks again.
Question on exhaust tune.. rough running at low speeds.. whodkne Speed Triple Forum 9 07-25-2007 06:33 PM
Rough running JTKMX Twins Technical Talk 1 10-04-2006 04:25 AM
new and rough running? maxed66 Speed Triple Forum 2 06-21-2006 04:39 PM
ROUGH RUNNING LOWEY Triumph SuperSports 16 04-15-2006 02:18 PM
Rough Running Anyone Spudgun Tiger Workshop 12 07-21-2005 05:45 AM
