Motorcycle.com
Old 05-09-2008   #1 (permalink)
Favorite Bike: 2007 bonnie black
650 triumph motor question
I am looking at purchasing a 650 triumph motor to build a bopper. It is in another state, what kind of things should I look for besides the obvious stuff. Also what is one worth you think that is rebuilt and works? Its a 1969 motor that was rebuilt.
I am new to restoring stuff, thats why I ask, I don't want to get screwed over.
jfenton is offline   Reply With Quote
Old 05-09-2008   #2 (permalink)
Retired Legend
sweatmachine's Avatar
I'm going to move this to "classic, vintage, and veteran."
but you also should join/post on www.jockeyjournal.com
There are lots of helpful guys "in the scene" on that site.
alright alright alright
Bonnie cafefighter!
Old 05-09-2008   #3 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
The list is too long to cover everything with even a good guess, and without photos it's impossible to tell.
Taking someone's word that it was running can be an "iffy" proposition, sorry.
Main items:
Is the engine totally complete and assembled, all inspection caps, screws, nuts and bolts in place?
Are all the cylinder & head fins intact?
Any evidence of welding done to crancases, and/or any damage around aluminum fin/lip over the output sprocket?
Are the threads in the exhaust ports and spark plug holes clean and complete?
Can you rotate the crankshaft by rotating the kickstarter or it's shaft?
If the engine turns over, does it have good compression?
Any evidence of oil leakage ? (likely to have been cleaned up if it's for sale)
If you can rotate the engine, can you shift it down to 1st, then up through the 3 upper gears while you rotate it, and does the sprocket seem to turn faster and faster?
Look at the serial number area just below the left side of the cylinder base - if it's a 69, the serial number should be between DU 85904 and DU 90282, and the number pad area should be smooth.
- if it's a serial number with any other two letters besides "T120R", it should have little embossed Triumph logos with the number stamped over it. If the first two letters of the serial number are any combination with a "C" as the second letter, it is PROBABLY a '69.
If the lump passes all of the above checks, and you cannot get authentication on the rebuild work that was done, it certainly shouldn't sell for over $1,000 (I have 2 spares that pass all of the above, and I'll sell either one for a grand).
If the seller authenticates all the work, and gives you some kind of guarantee that it will run properly when you install it, it could be worth $2,500 or more. It's really hard to get any closer than that without seeing really good photos or splitting it open to see what's what.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 05-09-2008   #4 (permalink)
So you have two motors for sale? Are they rebuilt or original?
Old 05-09-2008   #5 (permalink)
Moderator
They are non-running, basically complete, rebuildable core components, needing total rebuild.
GrandPaulZ
Born Again Bikes
My Photos
Too bad I did not have a Triumph Motor! mr_badda_bing Biker Hang-Out 1 08-29-2007 08:38 PM
motor question pmurT Twins Talk 1 10-24-2006 08:50 PM
Sorry, but motor oil question... Hokie Sprint Forum 17 08-19-2006 09:48 PM
TRIUMPH where's my motor?!?!?!?! 2ndSpace Triumph, Models & Dealers 13 12-08-2004 06:53 PM
What about this Triumph Motor Oil? deller4210 Sprint Forum 10 03-18-2004 02:01 PM
