Sometimes fork seals can pick up a small piece of grit. An old trick is to slide a piece of photo film, perferated side down, between the seal and tube.. Slide it around the whole diameter. If it is grit this often removes it. or Maybe one of your buddies or wife got into your garage and pored some oil on the floor to yank your chain,
Piles of Miles with Smiles
