Motorcycle.com
Old 05-07-2008   #11 (permalink)
Favorite Bike: 1979 Bonneville 750
Well I was told about this by another friend of mine earlier today that i need to check the tube, I have a seal kit comin that should be here saturday which is when I can get back to the garage, and would have the chance to see if its going to be more than just the seal. I hope its the seal.
Mr. Sinister.
Mrsinister is offline   Reply With Quote
Old 05-08-2008   #12 (permalink)
Favorite Bike: '79 T140D Bonneville
McQueen's Avatar
Other Motorcycle: '71 T100R Daytona
Extra Motorcycle: '64 Norton N15
Originally Posted by John Dangerous View Post
You'll also want to closely inspect the fork tubes, if they pock marked from rust or badly groved, I would consider replacing them. Otherwise, you get the job completed only to fine you've still the leaking fork seals.
Exactly, my next point. Check them tubes!
My 500's LH tube is done. Pitted very, very badly.
+ Ton Up Club NorCal +
McQueen is offline   Reply With Quote
Old 05-13-2008   #13 (permalink)
mglemans86's Avatar
Sometimes fork seals can pick up a small piece of grit. An old trick is to slide a piece of photo film, perferated side down, between the seal and tube.. Slide it around the whole diameter. If it is grit this often removes it. or Maybe one of your buddies or wife got into your garage and pored some oil on the floor to yank your chain,
Piles of Miles with Smiles
mglemans86 is offline   Reply With Quote
Would this cause leaking fork seals..? buxtonmick Hinckley Classic Triples 3 04-08-2008 09:42 PM
Leaking front fork BlueBird Twins Technical Talk 4 05-26-2007 06:04 PM
Leaking fork seal...AGAIN! Sport Sprint Forum 1 05-20-2007 08:39 AM
Leaking fork seals exjay9 T3 Sport / Touring Forum 8 02-23-2006 07:14 AM
Leaking Fork - from the top OzBloke Classic, Vintage & Veteran 6 10-23-2004 04:11 AM
