Is the mark something that can be buffed out? Is the tank clear coated? You might want to try polishing compound to see if you can't smooth it down. Just be careful not to go thru the clear coat.
If its an indentation, when you put the tank badge on, can you still see the defect? If not why do anything?
No one is going to see the tank with the badge off. It might bother you knowing its there but over time I bet you'll forget.
Hey, What's this oil on the floor?
