Motorcycle.com
Old 05-04-2008   #1 (permalink)
Boyer Mk111 Ignition
I installed a Boyer Mk111 electronic ignition on my 70 Bonny. Ive had people tell me that Boyers work better with 6 volt coils. The instructions say to use 12 volt coils. What is best.
fogcutter is offline   Reply With Quote
Old 05-05-2008   #2 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
Fogcutter,
I guess it comes down to this: if your electrical system is perfect in every other way (eg battery in great condition, charging system perfect, wiring perfect, coils in great condition, spark plugs perfect, and copper-core leads with no suppression caps, then you can use existing 12V coils hooked in series, as per the instructions. If any of these things goes down in performance (especially battery), you may have trouble with 2 x 12V coils. The Boyer limits coil primary voltage to 400V, and if you're spreading this across 2 x 12V coils, that's 200V per coil. Enough to get a spark, but if anything starts to degrade, the spark will be weak. The good thing about using 12V coils is you can always slip the points back in, re-wire a bit, add condensors back in, and you're back up and running.
The other way of doing it is to use 2 x 6V coils - electrically the same as 1 x 12V coil with two HT outputs. This will be more forgiving in terms of electrical system degradation, and you get a stronger spark. The downside is the cost of 2 coils, and not being able to swap to points without putting the 12V back in. You can also get a single 12V coil with dual HT outputs.
I've tried both ways (12V and 6V coils), and currently have 2 x 6V coils - I won't be going back to 12V coils, because the ignition system is much more reliable in it's current config.
Hope this helps.
Pete
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 05-05-2008   #3 (permalink)
Pete, I have always used 12v coils with the MKIII system. On my TR6P I fitted the Micro power system with 1, 12v twin output coil. The micro digital system comes WITH a twin output, single coil................ my question, have you honestly felt any difference between 6 and / or 12volt coils?
Roy.
Old 05-06-2008   #4 (permalink)
OzBloke's Avatar
Hi Dagad,
This biggest difference I noticed was an immediate marked improvement (without changing anything else) in the number of misfires, especially at lower revs. This was well after I'd tried new plugs, leads, and battery.
BTW, was over in the UK Sept last year, toured Scotland, Wales and Ireland for about 4 weeks - lots of water and greenery over there!
Pete
Per Ardua Ad Astra
Boyer ignition question stu Classic, Vintage & Veteran 2 01-20-2008 09:28 PM
Boyer Ignition Troubleshoot dagboy Twins Technical Talk 1 10-02-2006 01:52 AM
Boyer Ignition Klicker Classic, Vintage & Veteran 2 08-06-2006 04:59 PM
Boyer vs. Sparx Electronic Ignition Trudie Classic, Vintage & Veteran 1 05-09-2006 10:38 PM
boyer ignition help please Classic, Vintage & Veteran 3 04-25-2003 02:54 AM
