Motorcycle.com
Old 05-04-2008   #1 (permalink)
Favorite Bike: 69 T100C
Cylinder Block removal,Cylinder TDC ?
I'm replacing the cylinder base washer because of a bad leak. Just needed suggestions for removal of the cylinder block, needed clarification on cylinder TDC. Bike is T100C w/ boyer
argie is offline   Reply With Quote
Old 05-04-2008   #2 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
After you pull the head, rotate the engine till the pistons are at BDC, all the way down. that way, the cylinder will free off at the lowest possible height (the crank will want to spin free and let the pistons rise, unless the bike is in gear).
As soon as you see some daylight, stuff some rags under the jugs and put rubber bands on the tops of the pushrod lifters so that they stay in thier proper bores.
That's about it.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
GrandPaulZ is online now   Reply With Quote
Old 05-04-2008   #3 (permalink)
Unless you're looking for an excuse to split the cases I'd put rubber bands on the tappets before you even start lifting
MisterJ115 is offline   Reply With Quote
Bonnie Cylinder Block 908MD904 Twins Technical Talk 16 04-10-2008 03:21 PM
tappet block removal tigercub Classic, Vintage & Veteran 7 03-18-2008 01:41 PM
1971 TR6C Cylinder Block Problem hisnameisjimmy Classic, Vintage & Veteran 17 03-06-2007 08:31 AM
Oil in 3rd cylinder Bluetiger901 Modifications & Workshop Talk 10 12-04-2006 04:58 PM
Cylinder head removal/reinstallation Osara Modifications & Workshop Talk 12 03-30-2004 02:14 PM
