While listing my T140V hydraulic hose shopping list I came across these parts.
Look pretty tempting.
Clutch cable.
http://www.venhill.co.uk/Hoses_&_Ca...78_HI_BAR/T01-3-107_TRIUMPH_CLUTCH_CABLE.html
Primary Throttle Cable.
http://www.venhill.co.uk/Hoses_&_Ca...HI_BAR/T01-4-126_TRIUMPH_THROTTLE_CABLE_.html
The Pair of Secondary throttle cables.
http://www.venhill.co.uk/Hoses_&_Ca...0/T01-4-106_TRIUMPH_THROTTLE_CABLE__PRS_.html
They indicate that they're designed from OEM originals with marine-grade stainless steel inner wire construction, flat wound steel conduit with ‘Bird-caged’ design for strength and durability.
And the cables have low-friction Teflon liners for a lighter action.
Do you think they're worthwhile?
Also, I think I'd come undone if they needed to be shortened.
Clutch cable.
