Motorcycle.com
Old 04-29-2008   #1 (permalink)
Favorite Bike: Bonneville
76 T140V Clutch problems
My clutch is such that I need to be superman to depress the lever in order for it to engage I attempted to adjust as per the haynes manual and the adj screw seems not to do anything my next is remove the clutch plates and clean them but what puzzles me is that it works fine except for the superhman strength required to pull the lever?? Anyone can shed light on this??
Thanks
EPThomas04 is offline   Reply With Quote
Old 04-29-2008   #2 (permalink)
Favorite Bike: '79 T140D Bonneville
McQueen's Avatar
Other Motorcycle: '71 T100R Daytona
Extra Motorcycle: '64 Norton N15
Are there any sharp(-ish) bends in the cable?
Does the clutch break fee easily and otherwise work well (besides the heavy action)?
+ Ton Up Club NorCal +
McQueen is offline   Reply With Quote
Old 04-30-2008   #3 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
I would suggest the 3 clutch springs in the pressure plate are done up too tight, probably to stop the clutch from slipping.
Take the clutch apart, renew the bonded plates if necessary (depth of material left on them), get the plain plates garnet blasted, replace the 3 clutch springs, and put it back together. Don't do the 3 springs up too tight, but tight enough to stop slippage at max power - I usually have 2.5 spring coils showing above the edge of the cup the springs sit in. Check length of operating rod. Adjust clutch operating mechanism, loosen evry adjustment off, start at adjustment screw/nut in the pressure plate, then to cable adjustment at gearbox outer cover, then at the hand-lever. Lubricate cable (if non-nylon).
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 04-30-2008   #4 (permalink)
.... Don't do the 3 springs up too tight, but tight enough to stop slippage at max power ....
Ditto that.
Experienced the very same.
ray
happyray is offline   Reply With Quote
Old 04-30-2008   #5 (permalink)
Favorite Bike: Mine
t100rc's Avatar
Oil the cable.
RC
'70 T100
'57 T110 (in a pile)
t100rc is online now   Reply With Quote
Old 04-30-2008   #6 (permalink)
Favorite Bike: 1970 BSA A65 Lightning
Monty's Avatar
Other Motorcycle: 98 Thunderbird
Extra Motorcycle: 79 Bonneville Special
Check clutch cable is well oiled and easy to move, are there any wire strands starting to unravel and bind on the outer cable?
Check the clutch push rod, sometimes these can start to bind, remove, check for rust or a build up of muck, etc and clean re-oil.
Sometimes you can get a build up of muck in the clutch spring holder housing, check there also.
Hope this helps.
Just remember Gramps!, motorcycles are meant to remind you of your youth, when you last remember being happy, so at least try to relive some of that memory.
Monty is offline   Reply With Quote
Old 04-30-2008   #7 (permalink)
Thanks
I disassembled the clutch and the springs sure enough were super tight so I ordered the shop manual and will redo the plates I am wondering what are the tolerance levels for them and if they were too oiled? they were rather mucked in oil.
Clutch Problems? RiderRocketman The Rocket Science Forum 3 10-21-2005 11:39 AM
Torque Specs for the Clutch cover of T140V JDx613 Twins Talk 1 10-13-2005 08:00 PM
Clutch Problems BonnevilleJoe Classic, Vintage & Veteran 17 09-13-2005 10:38 PM
Clutch Problems O-State The Rocket Science Forum 7 07-22-2005 08:15 AM
T140V starting problems Birles Modifications & Workshop Talk 2 05-18-2005 02:39 PM
