Dont get too confused. the BMW forums talk about this double plugging a lot. Some models have pinking problems. I think partly due to piston/head design and partly because those engines are very short stroked and have hot spots.
The Triumph will run with the higher compression partly because the alloy head allows it to run cooler. BUT, simply by retardingthe ignition a little will compensate for poorer gas. The reason or thinking behind twin plugging is by running retarded there is less time for teh mixture to burn. starting a flame at two points speeds up combustion. At best the improvement is marginal.
-IF- you really have problems do as suggested and slip a 2mm shim under the cylinder barrels.
Avoid running weak or rich. You can sometimes alter the timing curves by using stronger springs in teh ignition auto advance mechanism. That way the advancing is held back harder and longer.
A wise man learns from his mistakes..
A genius learns from other peoples mistakes.
