» Log in
User Name Not a member yet?
Register Now!
Old 2 Weeks Ago
Favorite Bike: 69 T100C
oil filter-screw off
Any suggestions for a manufacturer/model for a 69 500cc, also if installed would the guaze filter in the oil tank be eliminated ? Thanks for any advice
Old 2 Weeks Ago
Hi Argie, you could use the one from a Norton Commando. It fits in the return line but the gauze in the oil tank still remains. It does however filter the oil BEFORE it goes back to tank AND gives a little extra capacity. You can fit it below the swing arm on the frame down tube, easy for removing / fitting and allows you to flush the system at oil changes.
Roy.
Old 4 Days Ago
Newbie
Favorite Bike: 1975 T160
Roy.
How did you attach the oil filter to the frame - custom installation?
Old 4 Days Ago
OzBloke's Avatar
Favorite Bike: 77 Bonneville
Argie,
Take a look at this link - http://www.britishspares.com/16.php
They normally come in kit form, with everything you need to connect them up, uncluding the hose ,specific to your year/model.
I would suggest most Brit spares suppliers would have similar kits.
I fitted one to my 77 in 40 minutes, and no hassles.
Note that these things won't cure a partially or fully blocked sludge trap....but can drastically reduce the blockage of a new one.
Hope this helps
Per Ardua Ad Astra
Old 3 Days Ago
Ozbloke is right there, but if you just buy the Commando head unit it is a custom job to make the mounting. I used a clamp from a car exhaust and then a drop plate to fit the head of the filter unit.
Roy.
TT600 Oil Filter (Triumph OEM VS. K&N Oil Filter) spin Triumph SuperSports 14 06-11-2007 10:49 PM
Big screw up mayfiebl Twins Technical Talk 9 02-17-2007 10:59 PM
my first screw-up tekmoe Speed Triple Forum 24 12-18-2006 06:06 PM
Total screw up stu Twins Technical Talk 3 11-28-2006 10:54 PM
Fuel Filter/oil filter/oil type Anchorbend Triumph Twins HangOut 4 07-24-2005 12:00 AM
