Motorcycle.com
Old 04-27-2008   #1 (permalink)
suggestions wantwd MAP#6510/preunit mount
I contacted MAP afew weeks back to buy thier oil filter. They sugested th MAP6510(The one that looks like a little grease gun) for my 1959 #026434 frame. It does not mount where they suggested it would(Top monting BOLT on passenger footpeg mount/ behind the mount). I guess they gave me directions for a unit bike. The top right passenger foot peg mount is a stud welded to the frame and nothing cannot be bolted behind it. If I try the lower passenger mounting bolt the frame loop is in the way. The only way I can see to mount this filter in a reasonable place is by drilling a hole in the passenger peg mounting bracket/muffler hanger, but I fear it woulb weaken the mount. Before I go into an unwanted hack job to mount this, I'm asking if anyone here has mounted one on the pre unit frame and where and how? I'll also have to make copper oli lines to prevent crimping of the hoses, because on the different angles the line has to travel to hook back up to the return spigot.
Another question, If it is mounted with a lot of line, say in front of the engine, will it reduce the pressure it needs to lube the top rocker lines?
Martin Cvitkovich: www.thesplitbook.com
Red1959 is offline   Reply With Quote
Old 04-28-2008   #2 (permalink)
Favorite Bike: A65C 650 1964 BSA
Other Motorcycle: A65T 1971 BSA
Extra Motorcycle: TR6R 1969 TRIUMPH
hey pal i,m going thru the same thing tryin to figger out how to mount ,em piccys would help alot i kinda looked at maps catalog i think the secret is in the clamp that they do,nt have at the moment i,ve seen pics of that don,t appear too hard to fabricate i just ain,t got to it been workin too much any one got any pictures please
aprophet is offline   Reply With Quote
Old 04-29-2008   #3 (permalink)
hey red i,m working on bsa,s a 64 and a 71 i just got running i found a couple of links that may help you hope so pal my frame on my 64 has loops for the passenger pegs i might be able to make a smallish exaust clamp work hav,nt studied the 71 long enuf yet tried the truck exaust clamp idea the filter element fouled my sump on the oil tank oif
http://www.gabma.us/docs/filter_mount.pdf
http://www.britcycle.com/Products/631Series001.htm
hth cheers pal
Old 04-30-2008   #4 (permalink)
MAP said it can be horizontal vertical or anywwhichway but loose! I think the problem with the mounting instructions is they are written for unit bikes, not preunit. Since I am not running the regulator under the seat, I mounted it vertical using a regulator tab. I got one more connetion to make befor it is finis. Looks like it will be ok.////// What model is your Beezers? I had a 64 T-Bolt in 1969-71 and built a 66T-bolt in 1988. Great bikes!! Got any pics of yours? I uploaded 2 pics of my 59, but I have no idea where they are ! They have to be somewhere in the TriumphRat net, but like I said, I haven't found them. Does any one know how to upload one [here]?
Old 05-01-2008   #5 (permalink)
http://www.flickr.com/photos/24644936@N07/
a link to a coupla bsa s the one with the triumph tank is a 71 tbolt thats the one i just got running just recently the blue one is a A65C bacon says a 1964 rocket with rev counter i think the merican version was a tbolt ? the 71 is the before picture stil doing a few things to make her roadworthy then a little surgery to the 64 to get the speedo and tach working again i just need something to ride in the mean timetake care pal good luck on yours
Suggestions for a high mount? CYLax Daytona Deliberations 17 06-10-2007 05:03 PM
preunit crankcase breather red59 Classic, Vintage & Veteran 2 04-23-2007 11:58 AM
Have a Two Brothers standard mount, want a high mount Catamount Speed Triple Forum 5 05-15-2006 07:39 PM
preunit primary to 2 row chain red59 Classic, Vintage & Veteran 2 04-28-2006 01:00 AM
preunit generator red59 Classic, Vintage & Veteran 2 09-18-2005 03:29 PM
