Motorcycle.com
Old 04-25-2008   #1 (permalink)
Newbie
reusing clutch plates
feel a bit silly asking but....i have seen recommendations to soak clutch plates in oil before reassembly, others stating to clean them with varsol or similar cleaners. they seem to stick together more when oil soaked but i'm too afraid of what cleaners might do to the bonding agents to have tried the other option... any suggestions?
black&chrome is offline   Reply With Quote
Old 04-26-2008   #2 (permalink)
B&C, use specialist brake cleaner, either aerosol or from a tub. This is formulated to clean but not harm the adhesive. Not sure on your bike but............ the oil in the primary is for lubing the chain, ONLY!
DO NOT over fill and use what's reccommended for the bike. Unless you tell us what you have because there might be a better option.
Roy.
Old 04-26-2008   #3 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
I'm with Roy 100% on this.
Clean the plates, DON'T oil them.
Also, scuff up the plain steel plates on smooth concrete by whirling them in a circular pattern, to knock the glaze off them. Wash them afterwards.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 04-26-2008   #4 (permalink)
TBS
I always grit blast the plain plates with garnet, stops any possible clutch slip and also frees up the plates.
TBS is offline   Reply With Quote
Old 04-28-2008   #5 (permalink)
ditto with all of the above..
i scuff up the metal plates with 300 grit wet/dry, then spray off with brake cleaner..
while you are in there, check plates for straightness with a straight edge.
also de-burr the tabs that engage the slots.
check chain wheel & center for wear in the slots.. if heavy wear; replace them.
makes a huge diff, in clutch action.
last but not least adjust clutch springs so the plates lift off evenly.
this is done by turning engine over via/ kickstart and operating clutch, while adjusting tension.
oh, and be careful of proper pushrod adjustment. -j
NHOJ from Maine is online now   Reply With Quote
clutch plates Red1959 Classic, Vintage & Veteran 4 10-09-2007 08:18 PM
how to change clutch plates Miami955J Daytona Deliberations 2 01-10-2007 06:45 PM
clutch plates fraggle69 T3 Sport / Touring Forum 7 08-28-2006 07:04 AM
Clutch plates trypcil Modifications & Workshop Talk 8 01-19-2006 06:31 AM
Starter clutch access plates BillBo Hinckley Classic Triples 10 09-05-2004 03:47 PM
