Motorcycle.com
Old 04-23-2008   #1 (permalink)
Favorite Bike: 99 T595
Other Motorcycle: 78 T140E bobber (almost)
Extra Motorcycle: HD Roadking
Clutch cable help
HI
I have a 78 T140E that I have been working on for about a year now. Went to change the clutch cable and tried to adjust it so the lever returns when you let go. It dosent go back, it will if you push it back. So I removed the gear box outer cover and looked at the thrust plate and it does seem to work. could the spring be weak. also the clutch lever is free and not binding. Its a new cable does it need to be lubed? I am stuck on this one. This is a left shift bike any advise on putting the gear box cover back on. I really like this site and hope some of you tech guys can help me.
Steven S is offline   Reply With Quote
Old 04-23-2008   #2 (permalink)
Favorite Bike: all of them
Other Motorcycle: Thruxton, spd Triple
Extra Motorcycle: T140, BSA B50
first make sure your cable is not too long , a common problem
2 lube it
3 replace that little spring on the "ramp" mechanism under the cover
drlapo is offline   Reply With Quote
Old 04-23-2008   #3 (permalink)
To drlapo
HI drlapo
Thanks for your reply
The cable I got was a 8+ over stock and the reason I did this is becouse this bike is not stock its a hardtail with 14" apes. I got this bike on a bad debt and grew it love it. Now I am trying to complete it. I have completed most of it seat, tank, rear fender, custom made brake hoses ect. now I am down to the more technical stuff for me carbs, ignition stuff like that and I find this site very helpfull
Sorry to ramble, back to the cable what do you think??
As far as the spring I may just throw one in anyway I have it apart
Thanks for your help
Steve
clutch cable ricster Sprint Forum 9 02-23-2007 03:57 AM
CLUTCH CABLE ricster Sprint Forum 3 01-18-2007 12:59 AM
Clutch Cable triumph_955_st Sprint Forum 18 12-25-2006 06:31 AM
Clutch Cable thfwsf Sprint Forum 12 07-12-2006 01:55 AM
Clutch Cable burtonsimmons Sprint Forum 0 06-07-2004 11:44 AM
