Old 03-11-2008   #1 (permalink)
tools needed for engine teardown...???
I need to put new gaskets on my '72 T100. She leaks badly from the bottom of the clyinder and between the cylinder and head. Any special tools needed for the job?
vwbuge is offline   Reply With Quote
Old 03-11-2008   #2 (permalink)
Favorite Bike: Shovelhead.
Emanthehorse's Avatar
Other Motorcycle: 98 TBS
Extra Motorcycle: 1971 Triumph TR6R Chop.
If you're just doing a top end, then you don't need any special tools over and above things like piston slippers.
Make sure you mark the position of each pushrod so they can go back in the same place.
Try not to drop the tappets out of the block also, put a rubber band on them.
Take note of what O rings and washers etc. go on the pushrod tubes and their positions. It's easy to get confused on rebuilds when there are several years worth of pushrod gaskets and rubber rings supplied in the 'set'.
Emanthehorse is offline   Reply With Quote
Old 03-11-2008   #3 (permalink)
Where is the best place to get a quality gasket set?
I was considering "british only"
Old 03-11-2008   #4 (permalink)
They are "semi retired" and have a minimum order.
I'd check out British Cycle Supply.
http://www.britcycle.com
Old 03-12-2008   #5 (permalink)
I hat ordering from that **** catalog. I'll have to call and see if they have an aftermarket set available.
Old 03-12-2008   #6 (permalink)
Favorite Bike: '07 Scrambler; grn/silver
1759AG's Avatar
Other Motorcycle: '69 TR6
gasket sets
VW, sent you a PM
1759AG is offline   Reply With Quote
Old 03-13-2008   #7 (permalink)
So I am thinking about doing this job. I know what pushrods are and tappets and such. I was just anxious about pulling everything off, trying to picture what to look for.
I am just thinking out loud now.
tools needed to install pannier peter_s Twins Technical Talk 9 06-25-2007 03:11 PM
What tools are needed to remove the rear tire of a 97 sprint? Prezidentelect T3 Sport / Touring Forum 11 06-23-2007 06:25 PM
Engine bars on your Bonnie, help needed. fridaylover Twins Technical Talk 5 05-24-2007 11:22 AM
List of Electric Measuring Tools needed Johnmala Classic, Vintage & Veteran 11 02-13-2007 11:48 PM
used engine needed for an '03 Speed Triple Speed Triple Forum 3 09-17-2004 05:03 AM
