Old 03-03-2008   #1 (permalink)
Favorite Bike: 1976 Triumph Bonneville
Other Motorcycle: 1979 Honda CB 650
76 bonne stanchion seal replacement
hello gentlemen, i need to pick your brains for a moment. i have a 76 bonneville basket case and this is my first brit bike. i am starting to rebuild the front end. i had no problem getting the forks apart but the stanchion ( tube ) seals have me a little perplexed. i have a manual but i dont think a simple seal puller is going to tackle this thing. they seem to have a 3/16" thick aluminum washer over top?? its like as if this washer was pressed down over top. perhaps this is OEM and the seals have never been changed but i need to know if there is something special about getting them ( the seals ) out? i can use a slide hammer or drill, tap and pull them out but before i start anything drastic is there an easy way? OR if this is a factory set up do i need to do anything special first ( like cutting with a dremel)?
ecotrekker is offline   Reply With Quote
Old 03-03-2008   #2 (permalink)
Favorite Bike: 1979 Ducati 900SS
abmar's Avatar
Other Motorcycle: 1970 Triumph Bonneville
Extra Motorcycle: 1937 Ariel Red Hunter
My factory manual for a 71, which should have the same forks, doesn't show such a washer, nor does my Haynes manual. Are you sure the forks go with the bike? You never know with a basket case.
abmar is offline   Reply With Quote
Old 03-04-2008   #3 (permalink)
sounds like you got 79 seals in this one
KADUTZ is offline   Reply With Quote
Old 03-04-2008   #4 (permalink)
yep a washer
from the reseach i have found out talking to guys there were 2 kinds of seals. what i have is ether a later version or someone replaced the seals with this "kit". but there is a washer 1/8 inch thick overtop of the seal. but the good news is i supposedly do not have to remove it. the "newer leakproof seal" can be removed and replaced like an o-ring. i havent had a chance to play with it yet but if that is so the job is going to go like a breeze. i am learning that the manuals...even the factory ones dont tell you quite everything.
Old 03-04-2008   #5 (permalink)
abmar's Avatar
Why are you assuming that the original seals are bad? What is the state of the stanchions? The seals may work just fine when the bike is put back on the road. If not, its not too difficult to replace them at that time.
Old 03-04-2008   #6 (permalink)
doesnt matter
i am rebuilding the bike from scratch basically. since i have to replace the stanchions i am going to completely redo the fork...all seals, chrome, etc. i want a new old bike.
fork oil seal replacement. 68tri Modifications & Workshop Talk 2 09-14-2006 05:03 PM
Fork seal replacement kjartan Triumph SuperSports 3 07-14-2006 06:51 PM
fork seal replacement psds Classic, Vintage & Veteran 9 06-08-2006 06:29 PM
fork seal replacement- 99 S3 grunt11b40x Speed Triple Forum 0 10-30-2005 10:45 PM
Clutch Pushrod Seal Replacement? SoCal Modifications & Workshop Talk 1 05-03-2004 01:55 PM
