With all due respect Happy Ray, your describing an Amal Mark I carb, while a 79 should have Mark II's. On these carbs, there is a lever that connects to plungers on the float bowls of the carbs. These plungers have a rubber plug at the bottom that seals an air passage, richening the mixture for starting. To start one its lever down, throttle closed. The lever should stay down by itself to start and usually it helps to leave it down for a little while as the motor warms up. My 78 will not even fire without the lever down. However, if you kick it 4-5 times and it doesn't start its probably flooded. Then its lever up and throttle half open to clear the flood. The rubber parts are likely shot if they are original. I would go along with the other recommendations and disassemble the carb, soak in Berryman's cleaner. And when you put it back together put in new vitron tipped float needles and rubber choke plungers. Baxters in Iowa or Mitch Klemph in Minnesota are both good parts suppliers. Call them up and they'll fix you up with what you need. Also, I strongly recommend you get a factory service manual and parts book from them. Your going to need them if you hope to keep this bike on the road.
Good Luck
Mitch
