I bought some from an outfit in the UK that are not gauges but use stainless steel inserts in tubes similar to the old mercury filled tube type. I'll have to look tonight to get their name and address if you're interested. They work really well, but vacuum guages should too. You may not be drawing enough vacuum at idle to get a good reading. Screw the idle adjustment screws in til your getting a good reading, adjust each til you get the same reading on both guages, then back each idle screw out the same number of turns til your idling about 800-900 rpm.
You can also use the guages to check whether the cables are adjusted right and lifting the slides at the same time. As you open the throttle, the gauges should move in parallel if the cables are right. If not use the adjusters on the top of the carbs to set. Then reset idle.
