Originally Posted by tigercub
this was a salavge bike from ill.it doesn't have a vin # that i can go by. it appears to be a 1973 750. i got a clymer manual with it the trans seems more like a 650 but the camplate they show is on the top. mine is on the front side like a 750. i'am not an expert but i have owned a 71 bonneville and three bsa's so i know a little about these bikes.could they have put a 750 top end on a 650 bottom end or is this possably an early 750 that they used a 4 speed on like you said.
If there's no numbers on the primary side just below the cylinders, I have to wonder why.
Should be a raised pad with a bunch of little Triumph logos and then the engine number stamped over the top. If it's not there, some felon ground them off.
750 top end does NOT just bolt onto the 650.
What do the rocker boxes look like? 2 Long oval covers or 4 round ones? If it has the round cover, does it have the extra little round covers on the sides of the boixes? Does it have the nine or ten bolt head?
Camplate on the top was the 500 transmission.
