Soldered frame?
I tried to search this, but only ended up w/ electrical results.....................
In a recent discussion, the subject of soldered frame joints came up.
It was in reference to a powdercoater who refused to do a frame because it had soldered joints.
This was discovered by a guy who "decided to grind on what looked like welds, but turned out to be solder, and the tubes began to move around". I'm not positive what year or model it was.
Was this standard practice at any point in the Triumph factory?
Was this an attempt at a "fix" by an end consumer, or a shop?
The subject sounds familiar to me, but I'm short on any real information. If it is the case, the frame I have('59 Thunderbird) has a bent downtube and headstay. I thought it might be a good reason to replace the tubes and weld them in place unless the metalurgy forbids it.
Coo coo ca joo
