Old 02-11-2008   #1 (permalink)
kiwee's Avatar
Replacing camshaft bushes?
slowly been rebuilding the Tiger of the last few weeks and are now reassembling the motor. Everything has gone ok but I have replaced the camshaft bushes (right-hand side so far) and according to the manual the new bushes require no further machining/reaming after fitting. Problem is there is no way the camshafts will fit in the bushes. With a digital vernier they are approx. .100" to small. I fitted the bushes by the manual, heated case to 100 - gently, carefully pressed new bushes in (not butchered with a big hammer). Any body able to advise if these DO need reaming?
kiwee is offline   Reply With Quote
Old 02-12-2008   #2 (permalink)
kiwee
do not believe everything you read.
K
KADUTZ is offline   Reply With Quote
Old 02-15-2008   #3 (permalink)
Hi,
any new bush, sleeve needs to be reamed acc. to the shaft it belongs to.
No matter which supplier. No matter what make we`re talking about.
Ray.
happyray is offline   Reply With Quote
Old 02-15-2008   #4 (permalink)
TBS
Does anyone know where I can buy a long nosed reamer, so I can line ream the timing side cam bushes?
TBS is offline   Reply With Quote
Old 02-19-2008   #5 (permalink)
Favorite Bike: Bonneville 750cc T140V
Other Motorcycle: Hinkley fake Bonnie T100
A tenth of an inch ???????????????
English_Spanner is offline   Reply With Quote
Old 02-22-2008   #6 (permalink)
DAGAD's Avatar
TBS, contact Hughie Hancox, he will do it for you. He does charge a fee.
Roy.
Old 02-22-2008   #7 (permalink)
TBS
Will keep him in mind Roy, cheers.
Camshaft bearings Bazzer Twins Technical Talk 17 12-31-2007 03:59 AM
06 Sprint worn front fork bushes gavinb Sprint Forum 0 09-07-2007 04:05 AM
camshaft timing klc Twins Technical Talk 3 09-04-2006 07:32 AM
500 Small End Bushes on Rebuild HankQ Classic, Vintage & Veteran 3 10-13-2005 03:12 PM
camshaft degreeing Modifications & Workshop Talk 0 02-28-2004 12:40 PM
