AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 01-17-2008   #1 (permalink)
Favorite Bike: 1973 Tiger 750
jonkull's Avatar
Wiring Turn Signals
The wiring in my 1973 Tiger 750 is the last thing that needs to be sorted out before I start working on cosmetics. Right now it's a complete mess. I have the remnants of multiple wiring harnesses and a bunch of extra wires to nowhere. It looks like the PO just kept adding to it rather than fixing or replacing whet was already there.
I'm not going to be able to really dive in for a couple months and sort it all out...I just don't have the time right now. In the meantime I want to make the Burbank police happy and get some working directionals. I need a temporary fix until I can replace everything with a single new harness. I'd like to know if anyone knows if there's a guide or diagram anywhere that shows how to wire them while bypassing the wiring that's there already. In other words what needs to connect to what?
Thanks.
jonkull is offline   Reply With Quote
Old 01-17-2008   #2 (permalink)
Hot from battery or hot side of coil (if you want the signals to not work when the ignition is off) to the flasher box.
From flasher to a splitter near the front of the tank. Stock color code is white.
From splitter to white yellow wires from switch housings.
Green white on one side and green red on the other side are the leads to the turn signals, left switch for left signal, right switch....you get it.
Make sure that the signals are grounded with a ground wire.
An hour and a six pack and Bob's yer uncle.
Don't ask how I know this, because none of my old Triumphs, save one, had or has turn signals.
Mecchanica is offline   Reply With Quote
Old 01-17-2008   #3 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
Jon,
Send me a PM with your email address, and I'll send you a simple diagram.
Pete
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 01-20-2008   #4 (permalink)
jonkull's Avatar
Thanks for the help guys!
Help with re-wiring turn signals DurkaJosh Twins Technical Talk 5 11-04-2007 10:24 PM
Turn signals RandyDTFR Club Cafe 7 04-09-2006 10:36 PM
sometimes turn signals tacomaguy Hinckley Classic Triples 3 01-06-2006 09:24 PM
Wiring Diagram for turn signals on '00 RS jglithero Sprint Forum 3 07-01-2005 08:39 AM
Turn signals Trophy 2 08-09-2004 02:02 PM
