Old 12-16-2007   #1 (permalink)
Favorite Bike: Harley Davidson FLHRSEI2
BADBUD's Avatar
Mikuni questions
If you all have been following my progress with Lilly (1963 T120 Bonneville) you know she is now running again after 18 years on the center stand. But alas she still has a few "issues". Carbs are way too rich and have some gas running out of settling bowl overflow. The carbs are vm32 Mikuni's.
Is there a rule of thumb way to get carbs adjusted close off the get go, ready to be fine tuned. Say like, snug screw down and then back off one and one half turns or something of that nature.
She is starting on the first kick----- but she loads up when it is revved a little bit.
There are two adjustments on the carb, one small screw and one large thumb type screw.
I can pull carbs and soak in Berrymans again if need be.
Please check progress pics.
BADBUD
http://www.picturetrail.com/gallery/...5567&members=1
BADBUD is offline   Reply With Quote
Old 12-16-2007   #2 (permalink)
No point in trying to tune it if the carbs are flooding. Disassemble the carbs and clean them. Use a q-tip cut in half and chucked into a drill and some brasso or other metal polish to buff up the inside of the float seat. This is good for all carbs.
The thumbscrew is for the idle speed. The small screw is the idle mixture. Mikunis use a fuel bleed idle circuit, so moving the screw out richens and screwing it in leans, the opposite of Amals.
Mecchanica is offline   Reply With Quote
Old 12-16-2007   #3 (permalink)
BADBUD's Avatar
Float seat?
Wish I had a exploded view of this particluar Carb. Have searched the net to no avail. I find pics but no part names.
BADBUD
Old 12-16-2007   #4 (permalink)
Try MAP cycle in FL. Their paper catalog has exploded views and numbers. He also stocks the parts. I don't know if the online catalog has the same drawing.
Old 12-17-2007   #5 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
Your problem is most likely the choke plunger rubber seats. they dry up and crack, allowing fuel to continue to flow through the choke circuits even with the lever turned "off".
You can buy replacement rubbers anywhere that sells Mikuni parts.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
GrandPaulZ is online now   Reply With Quote
Old 12-17-2007   #6 (permalink)
i have vm round slide mikuni on my bike(t120) and they are better than amals!
i can give you the basic settings as i found them in an interesting booklet edited by the victory library(www.victorylibrary.com)
the settingsilot jet25-30
Slide cut:3.0
NEEDLE JET TYPE:159
NEEDLE JET SIZE:P-4,P-6
NEEDLE:6DH2
MAIN JET:230
AIR JET:1.0
Try to find this book,it's very complete and usefull and cheap...
clean the carb
you can find parts for your carb here: www.pro-flo.com/
those carbs are are really fine once tuned correctly
you can even adapt the triumph air filters on them(i did)
ben
when i ride i\'m always 17
peintremondain is offline   Reply With Quote
Mikuni ? MotT3 T3 Sport / Touring Forum 8 04-20-2007 06:52 AM
Mikuni Jets EDE Hinckley Classic Triples 2 12-05-2006 01:54 PM
Pods for Mikuni Spooner Speed Triple Forum 2 11-25-2005 03:47 AM
Mikuni rebuild joeshack Classic, Vintage & Veteran 2 08-31-2005 11:21 AM
Mikuni Carb panic Classic, Vintage & Veteran 10 09-22-2004 03:08 PM
