Progressive Insurance
BikeBanditShopTriumph.comTriumphPerformanceUSAAdvanstarMotorcycleShowsSportbikeTrackGearbritishcustomsMotorcycle.comAnnitori DistributingSpringfield Armory
CycleGear.com
Old 11-21-2007   #1 (permalink)
Newbie
Favorite Bike: Triumph Bonneville Americ
Other Motorcycle: 1976 Bonneville
Extra Motorcycle: 1977 BMW R100/7
clutch hard to free up
I have a hard time freeing up the clutch plates before starting my 1976 T140V Bonneville. I have had the primary cover off and adjusted the clutch basket, I have adjusted the push rod stroke , installed a new clutch cable, I run 20-50 castrol oil. The clutch shifts like butter when I,m riding. It doesnt drag, easy to find neutral everything is good except when you go to start the bike. IT is so difficult to free up that I have taken to pulling the clutch lever in and securing it when I park the bike. Just until it cools off, then I can release it,and then there is no problem. Please let me know of any suggestions you might have....THANKS
mailman is offline   Reply With Quote
Old 11-21-2007   #2 (permalink)
Moderator
Other Motorcycle: Britiron
Sounds like the only thing you haven't tried is new clutch plates.
Try MAP plates.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 11-21-2007   #3 (permalink)
How about the primary chain tension? It should be 3/8" total up and down in the center of the run with ten pounds of force when cold and with someone of your weight on the bike. Too tight can really foul things up.
Mecchanica is offline   Reply With Quote
"live free or die hard" Triumph? SCL18 Twins Technical Talk 4 05-24-2007 12:44 AM
Too little clutch free play? meyers_john Twins Talk 2 03-12-2007 12:04 PM
Free hard bags in oz ??? rodsprint Sprint Forum 3 08-23-2006 06:35 PM
Free Hard Bags? Nomore76 Sprint Forum 12 07-02-2006 11:15 AM
Clutch free-play? TheStig Sprint Forum 10 06-09-2006 01:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
