Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
Old 10-13-2007   #1 (permalink)
carb or fuel injected bonnie?
Hi,
If you had the choice of a 2007 carbed bonnie or a 2008 fuel injected version which would you choose. Probably easier to change pipes with no carb rejetting. Is it just the loss of the classic look that would make you choose the carbed version?
Thanks,
Ingramatic
Ingramatic is offline   Reply With Quote
Old 10-13-2007   #2 (permalink)
Favorite Bike: '74 850 Commando
Other Motorcycle: '79 T140E, '96 Trident
Probably better to ask this in one of the 'Twin Talk' forums, this is the forum for Meriden bikes.
But since you have asked, I am considering buying one of the new Scramblers. The fuel injection sounds good to me, if only 'cos word is that there is a significant improvement in petrol consumption. On a bike with a small tank, a few more mpg has to be a good thing. As far as appearance is concerned, the fuel injectors are styled to look like modern carbs, so you need to look closely to see.
Trouble is, I really dont like the black coated engine cases. The coating cracks, dampness gets under the coating, the casting corrodes, then the coating comes off in big flakes leaving the cases grey and powdery. (my Trident had a black engine when it was new, after going through an English winter or two it now has half a grey-ish white engine).
daveforty is offline   Reply With Quote
Saw the new fuel injected Bonnie ChrisV Twins Technical Talk 12 09-25-2007 04:10 AM
08' Bonnie - Fuel Injected DrewDesign007 Twins Technical Talk 49 08-13-2007 08:31 PM
Fuel Injected 885? BadMouth T3 Sport / Touring Forum 1 08-01-2007 04:51 PM
help- fuel sender-955 injected jabrady1234 Speed Triple Forum 0 06-21-2006 12:20 PM
Were any of the 855 tigers fuel injected? 00wabbit Tiger Chat 3 03-08-2005 04:11 PM
