Old 10-04-2007   #1 (permalink)
Favorite Bike: 1979 Bonneville 750
A few retro questions
I have a '79 in stock condition (minus paint). I ended up with a box of parts at a swap meet and started going through them. There's a set of retro side covers (new) that were in there, and an additional gas tank from a early 70's T120 I was thinking of installing on the bike. Quick questions:
1) I have to remove the stock airbox to install the side covers, but the zener diode is using it as a heat sink, is there something else I could use to dissipate heat or is it not that important?
2) The new tank is bigger, but will mount to the bike. It does not have the "bungs" for the under bracket like the existing tank does.... Would I be safe to not use the extra bracket?
Thanks!
Paul McNeil is offline   Reply With Quote
Old 10-05-2007   #2 (permalink)
Id personally advise you to ditch the original rectifier and zener and replace it with a boyer power box or typanium...much kinder to your battery, and a simple job to install..2 wires frm the alternator in, pos& neg out, and you can convert to neg earth simply...
649cc is offline   Reply With Quote
Old 10-05-2007   #3 (permalink)
Favorite Bike: '64 Norton N15CS
McQueen's Avatar
Other Motorcycle: '79 Triumph T140D Bonnie
Extra Motorcycle: '71 Triumph T100R Daytona
a '79 you say?
You'll have to come up with a new bracket or location to mount your RITA ei box. It bolts to the inside RH side plate.
+ Ton Up Club NorCal +
McQueen is online now   Reply With Quote
Old 10-05-2007   #4 (permalink)
DAGAD's Avatar
First identify if it IS a '79.......... is it a T140V or T140E? If it's an E it will have 3 phase alternator and probably still RITA ignition. If it's a V it will have single phase alternator and probably still points / condensers. Let us know what you have.
Roy.
Old 10-05-2007   #5 (permalink)
Diego's Avatar
If you do opt to keep the original rectifier and Zener diode (about the only part of my electrics I never did have problems with, ironically), it definitely does need ample heat sinking. The presence of airflow across the heat sink whenever the engine is running was one reason for mounting the Zener where it was.
John
Diego is online now   Reply With Quote
Old 10-05-2007   #6 (permalink)
It's a T140E, so I figured it was probably a 3 phase with negative ground. What is the RITA box a few of you have mentioned? I have looked into the new power box, the typanium one, but was out of stock where I checked. Will the power supply box elimnate the diode, rectifier, and the Rita box, or is there something more I'm missing here?
Old 10-05-2007   #7 (permalink)
no it just replaces the rectifier(diode) and zener..the rita is separate item Im pretty sure just the ignition module...but it has to be a 3 phase version...3 wires in pos & neg out...if the alternator has 2 wires its a single phase, 3 wires 3 phase (yes I know some of the old early 60s single phase had 3 wires but I doubt that would apply to a 79 model)
Old 10-06-2007   #8 (permalink)
Sparx makes a voltage regulator/rectifier combo in an "egg" heat sink, going with the retro look. Mounts up under the bottom fork yoke.
The airbox mounted zener was a bad idea, as the only zeners I have had to replace have been on either custom bikes with inadequate heat sinking or grounding and on OIF bikes. There isn't enough cooling air or mass of aluminum in the immediate vicinity of the diode. Since the stock single phase alternator barely puts out enough juice at idle to keep up with demand, especially with the lights on, that the engine would overheat at idle before the zener does.
I recommend fitting a three phase if you don't already have one. Three phase stators have nine poles and three wires whereas the single phase ones have six poles and two or three wires. The three phase kit will come with it's own regulator/rectifier and the "egg" unit won't work with that alternator.
Mecchanica is offline   Reply With Quote
A little too authentic retro... Ready to Ride Twins Technical Talk 6 02-12-2008 12:17 AM
Retro-look Speedy... Dax Speed Triple Forum 10 04-05-2007 12:17 AM
new retro seat rodburner Twins Technical Talk 7 09-04-2006 01:06 PM
retro kit....??? tnsen Classic, Vintage & Veteran 12 02-20-2006 02:57 AM
Retro 05 S3! Speed Triple Forum 16 04-14-2005 12:52 AM
