Crack the fuel cap to see if it's a question of fuel delivery, plugged vent in the cap? Do the ticklers send a good dribble of fuel out when you push them? Did the restorers change the coils to DC coils? The stock TT had AC coils. Are the ones you have cylindrical or not? A photo would help here.
Check the valve clearance.........two thou inlet and four exhaust when COLD.
Get the cylinder compression with a gauge. Well, that's a good start.
