Timing light hook up - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-09-2007, 09:34 PM   #1 (permalink)
Favourite Bike: 1970 T120R(unrestored)
Other Motorcycle: 2002 Bonneville
Extra Motorcycle: 1970 T120R(restored)
Set the points and wanted to check the timing,but I cant seem to get the strobe(brand new)to light up.Had the -ve clip to the -ve on the battery and the red to one of the engine mounting screws.Inductive clamp on the spark plug wire.
Any thoughts?
Thanks.
Just music and my motorcycles. Thats all I need.
retrobiker is offline   Reply With Quote
Old 09-09-2007, 09:47 PM   #2 (permalink)
I think you are supposed to hook up the timing light to a seperate battery than the one on your bike. I just did this the other day and it worked great.
GrayMitchell is offline   Reply With Quote
Old 09-09-2007, 10:21 PM   #3 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
Gray's correct....the factory manual says to use a "separate power source" for the timing light. I've use a battery charger in the past, but some of the new ones seem to need the charger to be hooked to a battery for the light to work. Even an old tired battery will do for the light.
Hope this helps: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 09-10-2007, 07:25 AM   #4 (permalink)
will do.
thanks,guys.
Old 09-10-2007, 12:43 PM   #5 (permalink)
htown16's Avatar
I just use jumper cables off my truck. I rigged up a little wooden box with couple of bolts sticking out to attach the free ends to. This prevents them from getting in a tangle and touching each other.
htown16 is offline   Reply With Quote
Old 09-11-2007, 09:21 AM   #6 (permalink)
Favourite Bike: '67 Triumph Bonneville
I use the on-board battery, but only if it's new and fully charged. The discrepancies are minimal.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 09-11-2007, 08:12 PM   #7 (permalink)
Using an external battery did it,but only on one side.I assume there is no current going through the left spark plug cable.
Could it because of the broken bracket that mounts the left horn as in picture?
Thanks.
http://i98.photobucket.com/albums/l2...kenBracket.jpg
I
Bungee hook idea tri650 Speed Triple Forum 1 09-18-2007 01:30 AM
GPS hook up Tooth Trophy 3 07-31-2007 05:50 AM
hook me up with some crash protection Ranger32 Speed Triple Forum 15 09-18-2006 07:19 AM
tach hook-up sho-me Twins Talk 4 08-05-2005 07:07 PM
Where to hook those bungee thingies? BigYuxx Sprint Forum 7 05-23-2005 09:46 PM
