I'd suspect the plug or plug wire. Perhaps the cap has a crack or a carbon track in it. The Hunt mag is dual fire, and so the coil/mag/points must be working or you'd get no fire at all.
Or the carb. Make sure you are getting enough fuel to it and that the needle is seated in the clip and slide properly. You might have to remove the air filters to get a finger on the needle to guide it into the emulsion tube without hanging up on the edge.
