help with bent frame - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-07-2007, 10:14 PM   #1 (permalink)
I just got rearended last night on my 78 Tiger. The bike slid and bounced quite aways. The rear tire is shoved forward, the forks look a little ascue. My question, is there anyone that actually straightens these frames or am I better off looking for another one?
78tiger is offline   Reply With Quote
Old 09-07-2007, 10:42 PM   #2 (permalink)
I don't know anyone in your area. But, I've had Dr. John straighten a couple of crashed frames for me. This guy is awesome, he makes them straighter than stock. He does a lot of racing bikes, not because they've been crashed, just to make them better than stock. He's got books of data on every frame ever made. There is a handful of frame shops out there, some use lasers, some use a ruler. You could check with your local hooligan racer guys or your local vintage Triumph shop for a referral.
As for the forks, take them completely apart if you have the means and roll the tubes and dampeners on a surface plate. Replace anything that looks suspect. When in doubt, chuck it out.
Good luck.
Weasel Pete is offline   Reply With Quote
Old 09-08-2007, 07:07 PM   #3 (permalink)
I'd worry about the swingarm mount point welded on the rear of the frame downtube. If this takes a good whack, or even if it's just gone high miles, it can crack here and cause an oil leak.
The OIF frames are pretty stout, so I would worry more about the swingarm.
If you need a 78 frame and swingarm, I have one. No title. Shipping from Hawaii will kill you, though.
Mecchanica is offline   Reply With Quote
disassembly pictures, bent valves and the motor out of the frame sweatmachine Twins Talk 25 04-10-2007 12:30 AM
frame blanks for frame / swing arm on 1050 ST PeirreOBollox Sprint Forum 0 03-11-2007 09:41 AM
Thruxton frame vs. Bonnie Frame HiVel Club Cafe' 5 09-20-2006 09:16 PM
bent rims ddg1313 Twins Talk 12 01-26-2006 10:44 PM
Thats bent it!!!! Speed Triple Forum 2 05-24-2004 01:00 PM
