First Triumph (1964 T120) Need Advice
Hello, I just purchased my first Triumph, and am very excited to learn about, and fix her up.
It is a 1964 T120 frame with a 1969 T120V engine, that has been chopped into a hard tail bobber.
The engine starts right up and runs great. The frame was cracked, so I took everything off and found 2 other breaks and am currently having that worked on.
My questions are:
While I have the engine off I plan on replacing all the cables and hoses. But I would like to do as much as possibly while its off to clean/fix it up... is there anything you would suggest doing?
What is the best oil (and gear oil) to use when I change that? Synthetic?
Would it be okay to put degreaser on the engine and pressure wash her?
Anything you would recommend is very appreciated, I am eager to make this a great bike.
Thanks
