hot engine (one side) - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-03-2007, 09:00 PM   #1 (permalink)
Favourite Bike: 1970 T120R(unrestored)
Other Motorcycle: 2002 Bonneville
Extra Motorcycle: 1970 T120R(restored)
I know this has been brought up before since I looked up some of the old posts.
I cleaned the carbs and jets,inserted new petcocks(the left one was sure messed up with kreme),set the idle ,checked the plugs and points (except timing) and think I have my starting issues resolved.The battery is freshly charged.
The tickler seems more responsive on the right than the left.The float position and tickler spring seem fine on the left.
The engine really gets hot ( pipe turning cherry red ) on the right side.
There doesn't seem to be any air leaks.The plug on the right is harder to insert than the left.
Any advice would be greatly appreciated.
Thanks in advance.
Just music and my motorcycles. Thats all I need.
retrobiker is offline   Reply With Quote
Old 09-03-2007, 11:12 PM   #2 (permalink)
Favourite Bike: 1970 TR6 Spring Gold!
Are you getting a spark on the left? Is the exhaust cool on the left?
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
Old 09-04-2007, 08:09 AM   #3 (permalink)
The left side gets warm,to about what it should be.Haven't checked for a spark.I'm assuming the cylinder is firing o.k.I do plan to get a timing light this week.
Thanks,Quagmire.
Old 09-04-2007, 07:51 PM   #4 (permalink)
Here's a picture of the exhaust which has gotten pretty dark.
I also hear some knocking now.I'm going to have somebody more experienced check it out before there is further damage.
http://i98.photobucket.com/albums/l2...ghtexhaust.jpg
Old 09-05-2007, 01:09 AM   #5 (permalink)
check the timing if you think fuel aint the problem...separate points eqals seperate strobing...gotta be fuel or spark...swap carbs over if in doubt
649cc is offline   Reply With Quote
Old 09-05-2007, 07:53 AM   #6 (permalink)
Thanks,649cc.I'll work on the timing next.
Old 09-11-2007, 10:12 PM   #7 (permalink)
Hey there,quagmire.I was wrong about the spark.There isn't any on the left side.I'm sure it's the plug since I get a spark if I switch plugs.Brings me back to my initial post.Could this be causing the right side to run hot?I also noticed the left coil got a little hot when testing for sparks.Anything to worry about there?
Thanks.
Old 09-12-2007, 01:51 AM   #8 (permalink)
The coils should BOTH heat a little equally when running. If static, then the coil which has it's points closed will be the only one to heat.
There are two problems, the left has a spark problem, the right has a heating problem. Overheating is lean mixture, advanced or very retarded spark, or an air leak on the inlet side. Check the balance tube on the inlet adaptors, is it in place and tight?
Mecchanica is offline   Reply With Quote
Old 09-12-2007, 07:27 AM   #9 (permalink)
Thanks,Mecchanica,I'll check out these issues.
Old 09-17-2007, 08:48 PM   #10 (permalink)
Just an update.I put new plugs in (the left one was dead),adjusted the contacts,throttle cables and recleaned the jets and synched the carbs the best I could.That seems to have resolved the hot engine problem.
Thanks for all your help.
Engine may be running too hot sen098 T3 Sport / Touring Forum 8 02-15-2008 11:57 PM
Engine noise when hot Black06 Twins Talk 13 07-07-2006 11:16 PM
engine excessively hot to touch? johnnycactus T3 Sport / Touring Forum 12 06-09-2006 08:23 PM
Is my engine running hot? MercuryMan76 Triumph SuperSports 5 08-11-2005 09:23 PM
hot engine Triumph SuperSports 3 06-15-2004 01:06 PM
