A little clutch trouble
Hello
I could use a little advice. I have recently replaced
the clutch inner drum assembly on a 71 bonneville 650. As well
as the cup and springs, pushrod & the gearbox outer cover. The
trouble I am having is now I can not set the clutch to work with the
kickstarter. I read the book and the forum both, still can’t get it set.
The pressure plate will lift when I pull in the handle and the kickstarter
works by the book method, but the bike will not roll free. I have
to really tighten the adjuster screw to get the clutch to work and then the
kickstarter will not work. In any case I know you shouldn’t have to do that.
So any ideas? Thanks
