T140ES Taillight issue
My 1982 T140ES is giving me problems with the taillight, i.e. blowing the bulb all the time...
Not sure if this is something the PO experienced as well, but noted one night that both the tail and stoplight (combo bulb) were gone - the bulb literally exploded, all the glass shreds in the case.
thought this was a strange one-off and replace the bulb (the 'normal' 5/21W) and started to look back regularly, but again the taillight was gone (the breaklight wire still worked).
replaced again - same story
then i put an 'earth' wire from the light directly to the battery, but again after some riding: tail-light gone
however this only seems to happen when riding with the headlight (H4, 35/35W) on, when riding with the pilot light on only, the taillight 'survives'
where to go from here ? thanks in advance for your ideas...!
fom
