Battery Discharge - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 08-24-2007, 08:32 PM   #1 (permalink)
Favourite Bike: 1970 T120R(unrestored)
Other Motorcycle: 2002 Bonneville
Extra Motorcycle: 1970 T120R(restored)
Battery Discharge
Help!
I came back from my short ride all smiles,let the engine cool off and then realized the battery is dead.I know I had a good charge before the ride.It only took about half an hour to recharge with the battery tender.This is the second time this happened in the last few days.The battery is fairly new.
Would appreciate any thoughts,suggestions.
Need to ride it down tomorrow to have a local restorer look at it.Any chance I might get stranded?I understand you dont need the battery for ignition on these bikes.
Thanks.
Just music and my motorcycles. Thats all I need.
retrobiker is offline   Reply With Quote
Old 08-24-2007, 08:49 PM   #2 (permalink)
Favourite Bike: 1970 TR6 Spring Gold!
What's your amp meter say when your riding? Mine will be in the negative when I have my headlights on but when I turn them off it will be in the positive. If your not charging the system your amp meter will show all negative.
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
Old 08-24-2007, 11:15 PM   #3 (permalink)
I'll be sure and check the amp meter tomorrow.
Thanks Quagmire.
Old 08-25-2007, 01:17 AM   #4 (permalink)
Hey there,Quagmire.I think I may have located the problem.The brown-blue wire to the negative terminal was frayed pretty bad,and was barely in contact.I crimped on and soldered a new lead,so hopefully the charging system will be o.k.The fuse seemed fine.The true test will be tomorrow,when I go for a ride.
Thanks again.
Old 08-25-2007, 01:56 AM   #5 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
note with headlite on break even point of your chagring system system is about 2800RPM
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline   Reply With Quote
Old 08-25-2007, 01:57 AM   #6 (permalink)
Retro
TRIUMPH
Old 08-25-2007, 02:46 PM   #7 (permalink)
Happy to state that the frayed wire was the source of the problem.Just got back after an hor and a half of riding.The charge seems to be holding up well.Regardig the amp meter,Quagmire,it stayed positive both ways,although with the head lights on it's closer to zero.
Nice feeling,when these problems come up and they are resolved eventually.
Thanks folks.
Old 08-25-2007, 03:05 PM   #8 (permalink)
Thanks for the info on the RPM's kadutz. I have been keeping an eye on the tach,and shfting gear more often.
Thanks.
H.I.D. (High Intensity Discharge) Conversion Kits crowder Twins Talk 1 09-04-2007 08:33 AM
Coolant Discharge After Ride BallaRAT_ST1050 Sprint Forum 3 11-29-2006 04:04 AM
battery tender OR battery tender junior? dml955i Speed Triple Forum 4 11-03-2006 09:12 PM
t120v discharge buggy Classic, Vintage & Veteran 3 04-13-2005 03:22 PM
Battery discharge Sprint Forum 4 07-19-2004 11:41 AM
