It's 3/8 BSF. You won't find it in a hardware store, at least not on this planet. The threads changed in 1969. The ones up through 65 had a long extension on them and were harder to access. Get the 66-68 item from a Triumph shop.
DO NOT overtighten, the web is very thin. Use the correct fiber washer and sealer, if necessary to keep the leaks to a minimum.
