Lean running - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-19-2007, 12:06 AM   #1 (permalink)
Newbie
Lean running
I have a 1964 Bonneville w/ twin amal monobloc 389's.
It's running so lean, it's overheating.
the engine is a recent rebuild, with big bore kit.
I can't get it to run rich enough, even though I have
changed the needle and main jets.
Any ideas?
TIA Paul
williambonney is offline   Reply With Quote
Old 08-19-2007, 05:09 AM   #2 (permalink)
is your timing right?...auto advance working?...what do your plugs read colorwise?...are both sides the same?.....airleaks on carbs? float levels correct? oil system working properly?...was it all Ok before the work and what did you alter
649cc is offline   Reply With Quote
Old 08-19-2007, 12:48 PM   #3 (permalink)
Favourite Bike: '67 Triumph Bonneville
I hope you had the cylinders carefully re-bored to "sloppy" (relative to modern) tolerances.
Sounds like you are scuffing your pistons; they'll stick solid if you don't have enough clearance for expansion.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 08-19-2007, 11:08 PM   #4 (permalink)
a bigbore kit would surely come complete ready to assemble and not have been rebored
Old 09-05-2007, 02:14 AM   #5 (permalink)
Newbie
auto advance
All of your questions have been addressed except for the auto advance.
How do I tell if that is working?
I went up one more size in the main jets and it's running
pretty well now.
Thanks, Paul
Old 09-05-2007, 09:33 AM   #6 (permalink)
Favourite Bike: 1970 TR6 Spring Gold!
Take the auto advanced unit out and make sure the springs work easily. there are two weights that move out as the rpm's go up. The springs give some resistance at lower rpm's so the timing isn't advanced until about 3000 rpm's. (don't quote me on those rpm's)
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
Old 09-05-2007, 12:54 PM   #7 (permalink)
666Bonneville's Avatar
are you running straight pipes? the bike leans out with straight pipes.
you could get new slides; size 2 1/2 make the bike run richer
Triumph.... Turns an ordinary man into a mechanic.
2006 Scrambler
2005 CRF 450
1959 Triumph Trophy
1950 Triumph Thunderbird
666Bonneville is offline   Reply With Quote
Old 09-06-2007, 09:38 AM   #8 (permalink)
strobed the timing on both cylinders...advancing OK...dont mess with the carbs before setting the timing properly
Old 09-06-2007, 03:56 PM   #9 (permalink)
The idle jet is replaceable, but if you can get highest idle by lightly bottoming the idle mixture screw and backing two revolutions out, plus or minus a revolution, then you are in the ballpark with the idle jet.
You should have a 106T needle jet stock, and you should be able to get a 107T if you order one. Er, two.
You want to make the bike overrich, and then tune back to ideal.
Are you running a new kit (Aerco) or have you redone an old Routt, Morgo, or Chantland kit?
Mecchanica is offline   Reply With Quote
06 Running Lean? rcaudill Speed Triple Forum 5 02-08-2007 09:39 PM
s3 running lean Radoo Speed Triple Forum 6 11-03-2006 07:22 PM
00 RS running lean Matthew77 Sprint Forum 4 05-21-2006 04:57 AM
running lean? roccopeterbilt Twins Talk 4 05-08-2006 06:12 PM
Running lean causes Backfiring?! SprintRiderEwan Sprint Forum 1 11-02-2004 11:58 AM
