67 t100R oil blowback tube - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-18-2007, 11:51 AM   #1 (permalink)
I am the new owner of a rather nice 67 T100R. The bike is clean, looks as though its been well cared for, runs like a watch. The blowback tube runs up to the rear fender. I notice that it does leak a little oil from the blowback tube while riding after getting hot. Maybe one drop every 10 seconds or so. Is this normal for the Triumphs? I am new to the Triumphs but have been a BMW owner for about 5 years......Hondas before that.
The last Honda I had was a 75 CL350 and it would "spit" a little out the tube. The BMW blows it back into one of the carbs.
I know the British bikes have their quirks. I bought it to tinker with........the BMW never needs anything but air in the tires on occasion and I'm through customizing it.
gparson5 is offline   Reply With Quote
Old 08-18-2007, 05:29 PM   #2 (permalink)
another question about oil level
How much oil goes into the oil tank? I dont see any line or dipstick. It is currently almost full.....about 1/2 inch from the top.
Old 08-18-2007, 08:40 PM   #3 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
You may have too much oil in the tank. You should be able to see the oil returning to the tank in a small stream while you are holding the revs at about 2,000, from roughly the 2:00 o'clock position while looking into the tank through the filler. If you don't see the stream, take out a bit of the oil; you can run extra oil in the tank for the hot weather, but the return must not be covered. You should be able to buy a cap with the dipstick on it, as came from the factory.
Sometimes, you can have too much of a good thing: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Oil Blowback tube 67 T100 gparson5 Twins Talk 2 08-18-2007 12:42 PM
Stripped flywheel bolt & oil tube valiantbultaco Classic, Vintage & Veteran 1 03-14-2007 02:02 PM
AI removes LEFT tube but what is the RIGHT tube for? ocguyocguy Twins Technical Talk 2 01-27-2007 12:10 AM
help - six inch plastic tube dropped in oil filler Syberian Tiger Chat 8 05-13-2006 01:27 PM
Oil in Crankcase vent tube. Sprint Forum 2 01-21-2005 02:58 PM
