Motorcycle.com
Old 06-11-2007   #1 (permalink)
Favorite Bike: 79 t140e bonneville
Now i don't want to get everyone excited, but i don't want to ask about what grade or type of oil i should use in my primary, rather how much should i put in, as i have just cleaned my sticky clutch plates, It's a 1979 T140E.
Thanks all.
dirtyharry is offline   Reply With Quote
Old 06-11-2007   #2 (permalink)
Your primary is contiguous with your engine (crankcase). So you only use whatever oil is in your engine.
Mecchanica is offline   Reply With Quote
Old 06-12-2007   #3 (permalink)
Hi Mecchanica.
Do you mean that the oil is supplied by the engine, or that i use the same oil that is in the motor?, if so how much?
Thanks.
Old 06-12-2007   #4 (permalink)
Use whatever you are using in your engine. Drain primary from plug at back lower end of primary. Refill with 350cc of engine oil.
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline   Reply With Quote
Old 06-12-2007   #5 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
The primary on the '79 "breathes" and gets oil feed from the crankcase through the left main bearing and several tiny drillings in the common crankcase wall.
Half a cup of engine oil in the primary, to get things started, will do fine.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
GrandPaulZ is online now   Reply With Quote
Old 06-13-2007   #6 (permalink)
thanks people, have done what was suggested and will see how the first ride pans out .Thank you all for your info.
dirty harry.
Old 06-13-2007   #7 (permalink)
Favorite Bike: 1978 Triumph Tiger 750
hobbit's Avatar
Other Motorcycle: XLH883C Sportster
Extra Motorcycle: 1978 CB750 Hardtail Chop
There isn't really much movement between the primary oil and the main crankcase, so I find it gets pretty crabby after about 500 miles.
Amazing things indicators . . . pity yours don't work.
http://www.aavmcc.com
hobbit is online now   Reply With Quote
Primary Oil dorkingbonny Classic, Vintage & Veteran 25 04-08-2008 04:59 PM
Trans And Primary Oil aceaceca Classic, Vintage & Veteran 4 10-26-2007 11:02 AM
primary oil firedog Classic, Vintage & Veteran 2 01-13-2007 02:40 PM
Primary Drive Oil dorkingbonny Classic, Vintage & Veteran 8 10-30-2006 11:21 AM
What oil for primary chain case if???? bushybester Classic, Vintage & Veteran 2 08-28-2006 09:21 AM
