Motorcycle.comAdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.com
Old 04-26-2007   #11 (permalink)
glw
Favorite Bike: Rocket III Classic
glw's Avatar
Other Motorcycle: 76 Bonneville
Looks like this was a good question. Thanks for the responses.
glw is offline   Reply With Quote
Old 04-27-2007   #12 (permalink)
Mine always has been a ***** when it sits a week or two. I use the method I got on this web. I have a loop made of a plastic wire tie in my jacket pocket. While I'm getting ready for a ride I slip out to the garage and pull the clutch lever in and slip it on. Most cases it free's up in 1-2 kicks. Pain in the butt whether it's a new Triumph or and old one. I try NEVER to shift with the motor running if I can help it. I don't recommend freeing the clutch up with it in gear either, done it twice. Makes you look stupid :brk:
okiecityflash is offline   Reply With Quote
Old 04-27-2007   #13 (permalink)
My bike sometimes sits a week or two at a time before I ride it. Usually it takes at least 3 or 4 kicks to free the clutch. However, by the time I turn the switch on to start it, it usually has built up enough oil pressure to turn the light off. So I'm thinking maybe getting some oil circulating before the engine starts might be a good thing and its not all wasted effort.
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline   Reply With Quote
Old 04-27-2007   #14 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
Good point, htown.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 05-04-2007   #15 (permalink)
Favorite Bike: 79 t140e bonneville
had same probem. started bike up, pulled clutch lever in and selected 1st gear and went sailing out through the garage door with clutch lever still pulled in. very scary!!!. when i use the bike now i put it in to gear pull clutch lever in and rock the bike back and forth to make sure it rolls.
old bonnies don't die they just get louder!!
dirtyharry is offline   Reply With Quote
Love my T100...wish it had a kick start kenhadie Twins Technical Talk 22 09-30-2007 10:59 PM
Kick-start on Rebel??? SBBonnie Biker Hang-Out 7 03-29-2007 09:41 PM
Kick start bbx45lc Twins Technical Talk 7 11-29-2006 01:28 AM
Kick Start Question/ Possibly Tuning 67-t100 Classic, Vintage & Veteran 5 08-25-2006 02:48 PM
