What is correct method to check primary chain tension? I made hook with coat hanger wire and hooked chain. Pushed chain down with screw driver as far as it would go and made mark. Pulled chain up with hook until tight and made mark. Difference between marks is 5/8". Manual says should be 3/8" slack. Chain seems noisy with engine running.
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
